In Reply to: check tv manual posted by Sam P. on January 23, 2003 at 08:18:46:
To Sam and Wayne,I can try putting the sets I have together. Even if it does
whack this TV, I wouldn't be too unhappy. As for how big a TV
and speakers would fit in 6', the shelf is about 5' off the floor,
so this 6' has to fit two speakers (32"), TV (30"), and the tuner,
dvd, etc (18"). Hmmm. That's 6.5'. I also need to fit the
center channel under/over the TV, so I can't easily put the tuner
and friends in the same place. This is going to be tight. I'll
keep ya'll posted.Thx, Chris
Follow Ups:
