Home » Sponsored » Pi Speakers » Upgrades for the Pi7 crossover
Upgrades for the Pi7 crossover [message #49206] Tue, 28 March 2006 13:29 Go to previous message
Kim Schultz is currently offline  Kim Schultz
Hi Wayne.
I want to upgrade my Pi7 crossover that started out with some cheap components.
I have looked at Jantzen copperfoil inductors.
14 Gauge 0.62mH 0.19ohm, or should I use the 0.56mH instead.
14 Gauge 1.00mH 0.24ohm
Do you think they will have a low enough resistance, or should I go with the 12 Gauge versions.
What about the 5mH inductor for the bass, what specs. should I look for there ?
I thought about the Janzten caps too, they are not that expensive, but I have no idea how they sound.
Previous Topic: Wayne, impedance compensation calculation?
Next Topic: Seven pi-18 photos?
Current Time: Sun Oct 18 01:08:23 CDT 2026
