Home » Sponsored » Pi Speakers » Midrange
Midrange [message #47969] Thu, 13 October 2005 14:37 Go to previous message
GrantMarshall is currently offline  GrantMarshall
Hi Wayne.
One of the options you mentioned for the cornerhorns in the past was a 3 way system with a midrange direct radiator in the front, and a second midrange over top of the bass in the corner horn section.
I was curious if I could do a 400-3000 range this way (the PHL's do this and I think you've mentioned over 250 in the corner works as a direct radiator) and what kind of efficiency boost does the second driver in the horn give?
Thanks in advance.
Grant.
Previous Topic: *Thanks Wayne*
Next Topic: ** Pi chart request **
Current Time: Sun Nov 01 08:00:13 CST 2026
