Home » Sponsored » Pi Speakers » best for SET's
best for SET's [message #47688] Wed, 07 September 2005 05:47 Go to previous message
sailor is currently offline  sailor
Hi Wayne, I have heard a horn system using an Edgarhorn for mids and knew immediately I wanted that sound. I have e-mailed Bruce Edgar a number of times but have never received a reply, then I recently discovered your site and forum but am unfamiliar with your products and need some help and advice please. Size of enclosure is not a problem but I am looking for the best possible sound from low powered SET's. Bi-amping is a possibility. I live in South Africa and JBL is unavailable but Eminence drivers are imported, though not the entire range. I can also buy a pair of Altec 421-8LF if you think they would be usefull in one of your or any other designs. It has been suggested that I consider a karlson enclosure for the Altecs. In my case I do not have corners to use but a friend who has asked me to help him with speaers has two corners to use on the short wall of a 17ft X 28ft well carpeted and damped living room. He is also in a financial position to import any drivers you might suggest. I have heard some single-driver systems and although impressive I miss the weight and slam necessary for greater involvment in the music but without losing midrange quality. Your ideas and recommendations would be greatly apprevciated.
Regards
Previous Topic: Donate to the Red Cross. get Speaker Cables
Next Topic: Eminence Beta12LTa -- best cabinet?
Current Time: Mon Nov 02 03:06:33 CST 2026
