Home » Sponsored » Pi Speakers » 2206
2206 [message #47162] Wed, 22 June 2005 01:03 Go to previous message
andreaspaulsen is currently offline  andreaspaulsen
Hi All
My pro fours are still in the shop and I am not sure they will have access to the livingroom (SWMO's opinion). So I am searching for other options. I am able to put a largeish sub (such as Bills T36S) under the (to be homebuild) couch. I have got a pair of 2206. They pialign in 0.73 ft^3 which really is a very small enclosure. Assuming cornerplacement hanging from the ceiling with the tweeter below the woofer, how low can I cross to the sub, hopefully around 60-70 Hz) ?
Wayne Do you still have the Pro 3 plans using the 2206's. If so, I would like a set.
Cheers and take care with the tablesaw.
Andreas
Previous Topic: Wayne can you email plans for the 3 pi theater
Next Topic: HF Compression driver without horn flare?
Current Time: Sat Nov 28 15:49:30 CST 2026
