Home » Sponsored » Pi Speakers » HF Compression driver without horn flare?
HF Compression driver without horn flare? [message #47150] Sun, 19 June 2005 05:13 Go to previous message
Paul Holland is currently offline  Paul Holland
Hi folks,
The following link describes a boutique / audiophile speaker, made here in Sydney, with similar design concepts to some of the pi speaker range, ie 2 way, ported, 15" woofer with compression driver, pro audio components.
I have not listened to them , and are afraid to enquire about the price,
but my efforts to reverse engineer an affordable DIY version has brought me to the pi site (here to stay!)
Anyway despite my divergence from the original plan, ( I will probably build a pi 8) I am curious about the designers using the TAD TD4001 sans horn flare.
Has any pi constructors tried this?
Is this common or uncommon practice?
Does this practice only apply to the TAD TD4001?
Opinions welcome.
http://www.deepaudio.net/html/product_info.htm
Other interesting construction details include aluminium / MDF sandwhich panels with minimum bracing or damping.
Has anybody experimented with laminated / composite sandwich panels?
Cheers,
Paul.
Previous Topic: 2206
Next Topic: Pro 3 Pi
Current Time: Sat Nov 28 15:37:13 CST 2026
