Home » Sponsored » Pi Speakers » P.audio driver.
P.audio driver. [message #44640] Wed, 19 May 2004 17:13 Go to previous message
Castlesteve is currently offline  Castlesteve
I`m still pursuing my high efficiency speaker goal and have just picked up a pair of P.audio drivers and horns to mate up with my 12 inch woofers.http://www.paudio-europe.com/products/db_product_2_5_pa-d34.htm http://www.paudiosystem.com/products/db_product_6_14_ph-240.htm . Will i be able to cross these over at around 1k to the woofer and then run them out to 20k or so or should i cross them lower and use a supertweeter. I`m just learning crossovers so i`m trying to keep it simple so far.
The Richard Allan woofers are old but respected units but difficult to get T/S specs. I found a post with these specs:http://www.diyaudio.com/forums/showthread.php?s=af0104fbd661f87cdc26a6946fa784b5&threadid=33249&highlight= it`s the CG12 woofer.
Thanks, Steve.
Previous Topic: Speaker on the Beach
Next Topic: 8pi question
Current Time: Fri Oct 16 14:24:32 CDT 2026
