Home » Sponsored » Pi Speakers » Field coil speaker replacement advice...
Field coil speaker replacement advice... [message #42893] Tue, 04 November 2003 07:12 Go to previous message
Neo is currently offline  Neo
I'm restoring an old 1950's I think floor standing Philco radio. It's got a field-coil speaker and the voice coil is rubbing. The field-coil seems good, so I thought I'd keep that, but replace the 12" speaker. The VC resistance measures about 5 ohms. For those of you unfamiliar with a field-coil speaker, the power supply choke is used for the speaker magnet - there is no permanent speaker magnet.
Any thoughts? Would an 8 ohm Eminance 12" work. I though I'd try my Theater Pi 4's tonight to see if they work.
Thanks,
Tom
Previous Topic: Any experience alpha 15 or another for open baffle ????
Next Topic: Journal of a First-time Builder - Pt 1: Assembly
Current Time: Sun Oct 18 06:19:36 CDT 2026
