Home » Sponsored » Pi Speakers » Woofer / alignment comparison...
Woofer / alignment comparison... [message #41317] Tue, 13 May 2003 04:28 Go to previous message
jeff mai is currently offline  jeff mai
Thanks for the response below, Wayne.
I've attached a graph comparing an intriguing looking Beyma 12K200 woofer to a JBL 2206H woofer in a Pi-Aligned cabinet. The T/S parms for the Beyma unit are:
Fs = 35Hz
Re = 6.2 ohms
Qms = 11.17
Qes = 0.229
Qts = 0.225
Vas = 160 liters
Cms = 383 um / N
Rms = 1 kg / s
n0 = 2.9%
Sd = 0.053 m^2
Xmax = 4.5 mm
Le = 0.8 mH
I also compared the Beyma unit in a "shelved" type alignment you mentioned in the previous thread. I think the Beyma compares well to the JBL, though it's distortion figures and build quality are certainly not going to match the JBL. Comments?
I guess my main questions are:
How realistically will these graphs represent the true frequency response? And, which sort of alignment is likely to give best in room response? And if the answer to the previous question is "it depends on the room" is it worthwhile trying to tailor the alignment to the room?
Anyone feel free to chime in.
Thanks,
Jeff Mai
Previous Topic: Interesting: Subharmonics
Next Topic: Hey Wayne
Current Time: Sun Nov 08 17:58:59 CST 2026
