Home » Sponsored » Pi Speakers » Corner horn suggestions
Corner horn suggestions [message #41112] Tue, 22 April 2003 22:27 Go to previous message
Dave Callan is currently offline  Dave Callan
Hello Wayne and others,
I'm moving soon and will finally have a dedicated listening room. Room dimensions about 15' by 12' with 7.5' ceilings, two good corners and a concrete floor. I want to try some corner horns for use with about 8 watts of tube power. I can't make the thermionic 7's fit but anything else is possible. What would you suggest for best sound quality? Ideally, I'ld like to use the PS2002's I already have on hand.
Regards,
Dave Callan
Previous Topic: Wayne -- anyone? Dual ducted vents possible w/Pi Alignment?
Next Topic: plans for 12" folded horn
Current Time: Sun Nov 01 01:31:36 CST 2026
