Home » Sponsored » Pi Speakers » High output compression drivers
High output compression drivers [message #39465] Fri, 13 December 2002 20:59 Go to previous message
Hey Wayne!
Haven't been around here in a while. I have been EXTREMELY busy! Started a new full time job, churnin' out the usual number of speakers, crazy stuff goin' on. Very busy. Just thought I'd touch base.
I'm revamping a lot of my P.A. line of speakers, and I'm looking for a compression driver which can deliver a little better output then the PSD2002's. They are a bargain and they sound pretty good, but when you start really cranking them, they get distorted. I'm looking for something with signifigantly more output (not necessarily more sensitivity) without all the distortion and harshness. I need a truly high output CD, but I don't want to stick with a 1" exit, and I'd like to keep the price down. The JBL's are simply WAY too expensive, by far...
Any recommendations? Actually, the main reason for going with the 1" exit is simply to maintain the top end treble and try to keep costs down... If you have a good combo for a high output 2" CD with a quality, but relatively inexpensive bi-radial lense to go with it... Please hook me up man.
Hopefully someone can help me out. Thanks!
P.S. Those quasi 4-pi's I was talking about a month or two ago are just about finished. They are sanded, and just need to be covered. I'll post pics soon!
Adam
Previous Topic: Plans for 2 Pi Tower
Next Topic: corner horns
Current Time: Sat Oct 17 14:09:43 CDT 2026
