Home » Sponsored » Pi Speakers » best horn for 2426h in Pi type system?
best horn for 2426h in Pi type system? [message #39148] Thu, 21 November 2002 12:47 Go to previous message
tdc is currently offline  tdc
What is the best horn for use with the 2426H in a Pi type system ? Currently I use a 2345 with a 4648 ( dual 2226J's).The crossover is a Pi JBL pro type that Wayne helped me get together. The distance to my listing chair is 16 ft. The old JBL lit calls this a short throw horn but I have seen folks refer to it as a long throw type as well. Is there any horn that people have used which is significantly different or better then the 2345 for an average to large home listening room as opposed to an auditorium?I like the sound I am getting but changing the horn would be the only easy tweek I could do. Or should I just leave it as it is? Thanks TDC
Previous Topic: foreplay freaks look out!
Next Topic: 2Pi cabinet questions
Current Time: Wed Oct 21 06:25:20 CDT 2026
