Home » Audio » General » System Grounding Tweak
System Grounding Tweak [message #4717] Sat, 16 February 2008 21:07 Go to previous message
I hadn't really thought about it before today, but an audio system's grounding integrity depends on the quality of the connection of the breaker box to the ground rod that's placed near it. This became an issue for me on Valentine's day when I bought my wife a new LED TV that I connected to the cable TV converter box and to my system. The immediately audible result was a ground loop hum. Removing the coax input to the cable box stopped the hum, so I knew I had a problem with the cable ground versus the electrical system's ground.
A quick internet search revealed that the first and easiest fix is to connect the cable ground and the electrical system ground to the same ground rod. When I checked this out I realized they already are connected to the same ground rod, which should make a ground loop nearly impossible UNLESS THE CONNECTIONS ARE CORRODED! What do you know, the house is about ten years old, and the outside copper leads from both the breaker box and the cable TV are severely corroded where they connect to the ground rod.
Pulling them and cleaning everything eliminated the hum. So even if you haven't gone to the dark side and placed an LCD TV between your speakers it might be a good idea to check your electrical system's ground and clean it if it's corroded.
Previous Topic: 1944 Philco Radio
Next Topic: Why?
Current Time: Thu Nov 26 17:27:31 CST 2026
