Home » Sponsored » Pi Speakers » Corner horn flare on 7 pi
Corner horn flare on 7 pi [message #38064] Tue, 27 August 2002 05:33 Go to previous message
Dan K. is currently offline  Dan K.
I have been looking at the designs for the 7 PI's you sent out, and there is something I don't understand. The picture makes it look as though the woofer essentially fires directly into the corner and only uses reflection. I would have expected the back corner of the horn to have a 'V' wedge that was part phasing plug and partly the first flare of the horn. Sort of like this:
__________________
|xxxx|
|xxxx|
Sorry I can't make better angles than that. I know this is a conical horn and not a W fold, but can you explain why there isn't such a piece in the back. I guess it is my assumption it would improve both loading and hi-frequency clarity.
Dan
Previous Topic: Tis a sad, sad day my friends...
Next Topic: Pi Subwoofer cabinet
Current Time: Fri Oct 30 17:07:16 CDT 2026
