Home » Sponsored » Pi Speakers » JBL 2446H question
JBL 2446H question [message #37911] Tue, 20 August 2002 21:37 Go to previous message
Jerry Parker is currently offline  Jerry Parker
Hey Wayne, remember when we were over last time you talked about how the 2446H's 4" diaphram was so big that it basically was done at around 10khz, and had troubles with any higher frequencies? Well, what do the Pi speakers with the 2446H do for high end extension? Are they more designed for a sound reienforecement application than home use?
Also, I never really understood the whole concept of cone diameter relating to wavelength and upper frequency response. I know that as sound waves get higher in frequency their periods become shorter, but how exactly does this relate to the diaphram's size? I would assume that diaphram weight is not so much of an issue, so why could a 15" woofer not perform up to 20khz? If I remember correctly the larger the diameter the speaker is, the larger the off axis drop in higher frequency spl there is. Does it have anything to do with how the horn loading of speakers works? Thanks!
Previous Topic: Effects of horn loading
Next Topic: 2 Pi Tower Speaker Plans
Current Time: Sun Nov 22 22:52:15 CST 2026
