Home » Sponsored » Pi Speakers » Crossover question(s)
Crossover question(s) [message #37883] Mon, 19 August 2002 10:17 Go to previous message
On the 4Pi Pro's....or any of the crossovers I guess, would it be worthwhile to build R1 and R2 using higher than rated resisters,
ie. using 4 25 watt 120 ohm resisters all tied together in parallel to make a 100 watt 30 ohm resister, or what ever combination works out to get a value higher than a 40 watt rating, or is that a waste of $$$$.
Kelly
Previous Topic: Two Pi's Up and Running!!
Next Topic: more on (or moron on ) crossovers
Current Time: Fri Oct 16 04:41:24 CDT 2026
