Home » Sponsored » Pi Speakers » Reverse Horn ?
Reverse Horn ? [message #37495] Thu, 25 July 2002 14:34 Go to previous message
Anonymous
The question of the day is.. Lets compare two scenarios
and perhaps you can tell me what is going on.
Scenario one. You have an 8" midbass driver in a box
crossed over from 70hz to 500hz.
Scenario two. You desire to replace that 8" inch driver with a
12" midbass driver but don't have the space on the front baffle of
the box because there is only 8" width available, so you compromise
a little bit and you recess the 12" midbass ~6" to 12" inside the box
and taper the wall so the energy squirts out of the 8" opening on
the front baffle.
Questions are;
How much senstivity will you lose, isn't this sorta like a reverse
horn effect sensitivity-wise?
How much more "punch" in the music do you gain, if any, vs. the 8"
driver?
Previous Topic: set up is complete!
Next Topic: Canadian JBL Pricing
Current Time: Sat Nov 21 18:53:51 CST 2026
