Home » Sponsored » Pi Speakers » Cornerhorns!
Cornerhorns! [message #37435] Mon, 22 July 2002 02:41 Go to previous message
Recent discussions about various horn shapes prompted me to revisit the tried-and-true π cornerhorn.
The flare of a π cornerhorn is literally the room's corner, itself. Eighth-space loading provides DI gain of 9dB over free space, a significant amount. Directivity is uniform down to as low frequency as the room will support, much lower than any horn alone could do. The forward axis crossing point is ahead of the listeners, improving stereo balance over a wide listening area. And the best part about this implementation is that it is so simple.
Response from this configuration is very smooth, and coverage is uniform. All sound is directed into the listening room, bounded by the walls extending from the apex of the corner. So the π cornerhorn is one of my favorite configurations. it is extremely simple and works very well.
Previous Topic: A wierd question
Next Topic: Theater 4 Pi plans!
Current Time: Fri Nov 13 06:46:55 CST 2026
