Home » Sponsored » Pi Speakers » Wayne - Is this a WACKY idea?
Wayne - Is this a WACKY idea? [message #36007] Wed, 17 April 2002 12:38 Go to previous message
BobCat is currently offline  BobCat
Wayne,
I am considering building a Two Pi with a slightly different twist.
What do you think of mounting a second 10" Eminence Alpha woofer on the back baffle to compensate for baffle step? The second woofer would be wired in Push-Push configuration. The reason I ask is there has been quite a bit of discussion regarding Push-Push implementation on the Single Driver Forum. Also, the Vandersteen 2CE's utilize a rear "acoustical coupler". The acoustical coupler is a larger woofer than the front woofer. I would double the box volume by doubling the vertical dimension and adding a second port. Are there drawbacks to this configuration? Is this feasible or just plain wacky?
Also, what is the shipping cost for a Two Pi KIT to Dubuque, IA 52003? Is the port included in the kit?
Best regards,
BobCat
Previous Topic: Contemplation on combined Sensitivity(long)
Next Topic: Binding posts vs 1/4 inch jack vs XLR vs Speakon
Current Time: Sat Nov 14 13:46:15 CST 2026
