Home » Sponsored » Pi Speakers » Crossover Doc Spcie models
Crossover Doc Spcie models [message #35497] Thu, 14 March 2002 15:13 Go to previous message
dbeardsl is currently offline  dbeardsl
Wayne,
Thanks for the info.
I'm probably not doing something right.
I used your exact spice model in the crossover doc for the Delta 15 and the psd2002 with a simple firt order butterworth.
I put the current source across node 5 and 0 like you said, and measured the voltage at node 6 and 1. I get something cloe to yours, but not quite the same.
Here is the spice model...
Delta 15 and PSD 2002 with 1st order Butterworth
! First order network
L2 5 6 0.6mH
C2 5 1 16uF
! woofer virtual circuit (Eminence Delta 15)
! voice coil reactance
R3 6 7 6.9
L3 7 9 0.86mH
! mechanical reactance (40Hz, Q=6.56)
C5 9 0 400uF
L5 9 0 40mH
R5 9 0 65.6
! tweeter virtual circuit (Eminence PSD2002)
R4 1 10 6.6
L4 10 11 0.1mH
! mechanical reactance (on H290)
C6 11 12 20uF
L6 11 12 2mH
R6 11 12 100
C7 12 13 10uF
L7 12 13 1mH
R7 12 13 100
C8 13 0 5uF
L8 13 0 0.5mH
R8 13 0 100
R9 11 0 20
C9 11 0 50uF
I 5 0 AC 1
And the link is the graph I get.
Am I doing the graph wrong.. I expected it to be exactly like the one pictured, I tried different voltages, but of course I get the same thing, just a little up the scale.
Previous Topic: Using APT-50 or 80 or 130
Next Topic: Active crossover vs passive crossover
Current Time: Wed Nov 04 15:58:12 CST 2026
