Home » Audio » Group Build » Guinevere wired and ready.
Guinevere wired and ready. [message #30878] Mon, 07 March 2005 18:29 Go to previous message
Well; all the wires are soldered and dressed. I will not power up until tommorrow. I need to check all leads and joints and want to start fresh. I think the only possible problem may lie in those SS things. I mounted the LED's on a seperate strip with it's own ground. The heater supplies work on both tubes and I am pretty confidant of the PS. Time will tell.
I am going to use one of the gainclones to test at first just in case!
If there are no problems you will hear from me. If you don't hear from me send mass cards to Our Lady Of Lourdes.
Previous Topic: Location of Selector Switch in Preamp
Next Topic: Troubleshooting
Current Time: Fri Oct 16 04:49:53 CDT 2026
