Home » Audio » Group Build » Advice on mounting CCS
Advice on mounting CCS [message #30749] Sun, 27 February 2005 12:43 Go to previous message
Guys; what are you all doing with your CCS. Are you shock mounting them to the chassis with bolts and nuts?
Are you tieing the output wire's to the solder tabs then letting them hang?
Are you glueing or taping the little perfboard squares to the underside of the chassis then wireing them into the circuit?
Maybe using very short wires and tieing them to the tube pins like Bottlehead does?
Which method is most appropriate for this application?
Thanks; J.R.
Previous Topic: hi Damir and all
Next Topic: Common cathode biasing
Current Time: Thu Nov 05 23:57:05 CST 2026
