Home » Audio » Craftsmen » Filler for mitered edges that aren't flush?
Filler for mitered edges that aren't flush? [message #29820] Fri, 20 October 2006 19:14 Go to previous message
Riot is currently offline  Riot
Working with African Mahogany. I've got maybe a 1/16" gap on 2 mitered corners. Started using one of those colored wax pencils, but not sure this is going to fill it. Also, I mis-drilled a screw hole and need to fill it as well. I'm only using a thin resin-based lacquer (dammar crystals dissolved in turpentine). Any advise on what to use to fill?
Previous Topic: An uncraftsman question-- Cabinet grade plywood
Next Topic: Guess I'll have to build another base for the amp
Current Time: Mon Apr 29 07:03:52 CDT 2024
