Home » Audio » Craftsmen » "Whatever the question: Tri-Flow is the answer."
"Whatever the question: Tri-Flow is the answer." [message #29774] Sun, 03 September 2006 18:20 Go to previous message
Are any of you hip to this? Gunners? Cyclists?
I bought it recommended at the bike shop for the chain.
Now I use it instead of any other lubricant for everything. Maybe even mixed with the oil for the turntable.
There are quite a few; I'm using 'with teflon'.
Previous Topic: Two Hundred hours of work
Next Topic: An uncraftsman question-- Cabinet grade plywood
Current Time: Fri Nov 13 05:31:10 CST 2026
