Home » Audio » Craftsmen » Conical horn project
Conical horn project [message #29711] Sat, 31 December 2005 15:47 Go to previous message
Hey-Hey!!!,
I have an 8-petal conical horn on paper for a pair of AlNiCo RCA compression drivers. 1-3/8" throat and 18" axial length on a 35-degree included angle.
With the trapezoid petals cut to size, what would be the best way to get the 22.5-degree chamfer on the edges?
Since I have little in the way of tools, I suspect that paying somebody might just be teh easiest. I have a router, and can get the 22.5-degree chamfer bit, but holding the work so as to reduce opportunity for a mistake is a bit of a task I think.
Anybody feel like taking a shot? trade for ____? I have anything from tubes to amps to put on the block. Or if somebody shares some magic, I'd be off on my own.
cheers,
Douglas
Previous Topic: So you want some expensive cone feet?
Next Topic: Bonding metal to wood
Current Time: Thu Nov 26 09:02:12 CST 2026
