Home » Audio » Craftsmen » Solid State vs Vacuum Tube Finish
Solid State vs Vacuum Tube Finish [message #29594] Fri, 09 September 2005 11:49 Go to previous message
I was finishing off a few projects in the past couple of weeks and it dawned on me as to what irks me about polyurethane finishes. It's solid state compared the vacuum tube you get with oil finishes.
When poly dries, light does not seem to diffuse through the layer of finish. Rather, reflections happen on the surface, resulting in very crisp and sharp refelctions. Look closely at light points on poly finish and they all have sharp edges. Clinical to a fault.
Oil finished (tung, linseed, etc) on the other hand gives soft diffused reflections, where light points have fuzzy edges. Warm and lucious.
G.
Previous Topic: PI four enclosure
Next Topic: Tuba18 Sub
Current Time: Thu Sep 24 23:46:38 CDT 2026
