Home » Audio » Craftsmen » Jointer and Plywood
Jointer and Plywood [message #29398] Wed, 02 March 2005 11:10 Go to previous message
Cantskienuf is currently offline  Cantskienuf
Can I use a jointer to get a flat edge on plywood, or will it splinter the outer surface? Seems that on my larger cuts I sometimes get a slight pinch on the table saw making the edge a bit less than perfect. The inner plys don't seem to be too happy if I try to smooth the edge up with a finish sander.
Previous Topic: New Project
Next Topic: The Lynn Sabin Jig: A Great Box Joint Jig
Current Time: Thu Aug 20 08:31:33 CDT 2026
