Home » Audio » Craftsmen » Need help with Polyurathane.
Need help with Polyurathane. [message #29165] Tue, 20 July 2004 08:47 Go to previous message
James W. Johnson is currently offline  James W. Johnson
The guy at Lowe's suggested I use a low nap mohair roller....boy was he wrong. After applying the first coat I hurried as fast as I could to try and undo the bubbly mess the roller made with a brush. I smoothed it out and scraped off as much excess poly as I could.
It turned out better than I expected but still the coat was too thick.
How can I fix this? Will over sanding the poly mess up anything for further coats?
I am using Minwax fast drying satin.
Please help!
They sure look good from 2' and camera shots though. :D... but that wont do , I need close inspection good looks to some degree.
Previous Topic: Staples Redux
Next Topic: How do you spell Formica?
Current Time: Thu Nov 19 16:08:52 CST 2026
