Home » Audio » Pro Sound » On my way to a Nobel Prize
On my way to a Nobel Prize [message #28359] Sat, 31 January 2004 07:31 Go to previous message
The only problem I have with Rane gear is that some of my boxes have tiny push button on-off switches. They're very easy to accidentally hit, and if it happens to be something like a crossover, there's real potential for havoc.
I glued some plastic advertising magnet stuff together to form a sheet about 3/16 inch thick. Then I made washers out of it, the center hole the diameter of the on-off buttons. When the buttons are depressed I put the washers over the buttons (they stick to the faceplate without marring it) and cause the power button to be recessed. This makes it nearly impossible to accidentally depress them.
Anybody want to nominate me?
Previous Topic: Problem with Marshall DSL401
Next Topic: using guitar amp heads with a bass speaker?
Current Time: Fri Nov 13 05:30:54 CST 2026
