Home » Audio » Pro Sound » Peavey speaker questions
Peavey speaker questions [message #28336] Fri, 27 June 2008 01:40 Go to previous message
Mike Gibson is currently offline  Mike Gibson
Our museum has a pair of Peavey Sp 6G speakers. On one the woofer only works when you plug the jack into the low plug as if you were bi-amping. So the woofer is good. On the two full range ports only the horn works.
The crossover has a built in proprietary "Sounf Guard" that only protects the horn. My questions are-What normally goes bad to cause this? It has to PCB's in it. A small one where the phono jacks plug in and the one with the crossover and the protection circuit.
Is there one thing that goes wrong normally or what? I i,agine I'd have to buy the whole board or maybe both.. Any help would be appreciated.
Mike
Previous Topic: need help with amp
Next Topic: ampeg vt-22 head
Current Time: Fri Nov 20 07:35:18 CST 2026
