Home » Audio » Pro Sound » Paging BillF, GraemeG and SwollenL - Massive hornsub
100dB/watt at 20 Hz is overkill. [message #27863 is a reply to message #27862] |
Mon, 15 March 2004 12:59 |
Bill Fitzmaurice
Messages: 335 Registered: May 2009
Grand Master |
I personally would recommend against trying for max SPL from a horn-loaded sub to 20 Hz, assuming that means you want to get at least 100dB/watt at 20 Hz, simply because there isn't enough program power down there to justify it. In my 'Tuba 24' article you can read how I did a series of RTAs at a 6,500 seat concert venue featuring over 30 top acts of various genres from C&W to Metal, and consistently the highest power requirements were from 60 to 100 Hz, with levels at even 40 Hz down 25dB from those at 60 Hz. This was not a product of the sound systems being used, usually at least a dozen 18 subs. In terms of what is actually required for live pro-sound a better way to go is a stepped response curve, with maximum SPL from 60 to 100Hz, where it's needed, and a more modest output capability below that where it isn't, and that's where my designs for live-sound subs are heading. On the other hand, for HT a lower Fc is required, but at far lower levels, so my HT designs are aiming for just that, a lower Fc along with lower SPL to keep cabinet size within reason.
By: DanR on Mon, 15 March 2004 11:09
Re: Paging BillF, GraemeG and SwollenL - Massive hornsub
By: DanR on Mon, 15 March 2004 11:59
Re: 100dB/watt at 20 Hz is overkill.
By: DanR on Mon, 15 March 2004 14:04
40hz even seems really impressive with PA
By: Mike.e on Mon, 15 March 2004 18:06
By: GraemeG on Tue, 16 March 2004 05:07
Magnum hornsub
Re: Magnum hornsub
Re: Magnum hornsub
MAG12 - Preliminary Announcement
hmm
By: Mike.e on Tue, 16 March 2004 16:52
Where are you?
New Zealand/.
By: Mike.e on Wed, 17 March 2004 01:55
Re: hmm
My philosophy is-
By: Mike.e on Wed, 17 March 2004 01:59
Re: MAG12 - Preliminary Announcement
By: DanR on Wed, 17 March 2004 10:33
By: jason on Wed, 17 March 2004 13:37
By: hulkss on Thu, 18 March 2004 17:47
By: bill W. on Thu, 18 March 2004 21:52
Driver Frame Diameter
By: hulkss on Sat, 20 March 2004 10:07
Re: Driver Frame Diameter
Project News
Magnet weight
By: jason on Sun, 21 March 2004 18:43
Re: Magnet weight
Magnet structures
B12 - Eminence requests that the driver formerly known as MAG12 be called the B12 instead
By: GraemeG on Tue, 16 March 2004 05:23
Current Time: Sat May 18 15:13:16 CDT 2024
