Home » Audio » Pro Sound » JTM pre-amp valves
JTM pre-amp valves [message #27090] Tue, 05 July 2005 04:20 Go to previous message
Matt5104 is currently offline  Matt5104
Hi, I have a JTM612 with 2 12AX7s, 1 12AX7EH and 1 marshall ECC83 in the pre-amp. I'm considering replacing them all with mullard ECC83s. Can I literally just replace them and power up the amp, or do I need to re-bias the amp? Also, does anyone know the best order in which to place the original valves in the pre-amp? I've heard that putting the 12AX7EH in V1 (first valve position from right to left) is best, but i'm not really sure! Thanks very much.
Previous Topic: Earth Sound Research BT-2000
Next Topic: Which Marshall?
Current Time: Fri Oct 16 21:10:06 CDT 2026
