Home » Audio » General » RCA cleaning tip...
RCA cleaning tip... [message #26423] Thu, 12 January 2006 17:49 Go to previous message
Hey-Hey!!!,
Pardon the pun, but a Q-tip makes an excellent cleaner for old RCA jacks. I peeled 95% of the cotton off, and applied a little bit of polishing wadding. Stuck the other end in a hand drill and spun it. Nothing like the proper power tool for a sensitive job!
Don't put too much of a ball into the end, as it might bend the inner contacts. Clean with a 70% peeled clean Q-tip( by hand ) and then peek inside when you're done. Nice clean, shiny contacts...:)
cheers,
Douglas
Previous Topic: My observation or hallucination :)
Next Topic: Celef PE1 Speakers
Current Time: Sun Nov 29 08:58:05 CST 2026
