Home » Audio » Room Acoustics » rigid foam
rigid foam [message #25056] Mon, 27 March 2006 22:25 Go to previous message
nodiak is currently offline  nodiak
I have access to several 4'x 8' sheets of Johns Manville AP Foil Faced Foam Sheathing. It is 3" thick.
http://www.jm.com/insulation/building_insulation/products/bid0022_ap_foil-faced.pdf
I thought if it is similar to OC 700 series I could strip off the foil and straddle 2' x 8' pieces of it across corners. Could add fiberglass behind it too if helpful. Anyone know,or can tell from the link, if it is useful.
Don
Previous Topic: Computer Simulation of Room Acoustics
Next Topic: Speaker placement
Current Time: Fri Nov 13 08:21:40 CST 2026
