Home » Audio » Speaker » All the speakers the same brand and size?
All the speakers the same brand and size? [message #23202] Thu, 28 September 2006 17:11 Go to previous message
Marlboro
Just thought of something that seems obvious, but maybe not....
Is it important for all the speakers in the array to be the same size and brand?
I mean suppose you upheld the c-to-c but some of them were Sammi's and some were Daytons, and suppose you made a woofer array where the bottom speaker was a 12 incher but all the ones above it were 7 inchers.
That seems crazy, but if you are using electronic crossovers, would it be?
Marlboro
Previous Topic: line array + front loaded horn ?
Next Topic: Center channel design with line arrays
Current Time: Fri Nov 06 22:27:09 CST 2026
