Home » Audio » Speaker » Line array question using Bandor 50mm driver?
Line array question using Bandor 50mm driver? [message #22278] Sat, 04 September 2004 21:31 Go to previous message
Hi everyone,
I have a few basic questions about what effects combing would have above the critical area where it starts by using the 4 ohm Bandor 50mm driver?
http://www.bandor.com/products_frame.htm
I would like to eliminate the use of any crossover components inline with these drivers in an array, but may just be dreaming.
Could the negative combing effect be allowed to be unchecked with out a problem to the overall sound quality of the array?
Also, would an array of tweeters be needed to compensate for the high frequency roll off of the Bandor drivers due to the combing effect?
The 50mm Bandor drivers are claimed to be able to go from 100Hz to 20kHz in a 2.5 liters sealed box.
There are a few commercial array speakers that use this drver with out a crossover or an extra array of tweeters to reproduce the high frequencies.
Could some type of EQ be used to boost the high frequency to compensate for the combing effect with out problems, again Duh?
It is obvious that I do not have a good understanding of the nearfeild effects of high frequency combing. I just read the white paper kindly offered by Jim Griffin for the first time, and very little of it has sunken in, maybe after reading it a few dozen more times. I do want to thank Jim Griffin for all of the work that he has put into this white paper and bringing it to our attention.
Mini array: http://www.seventh-veil.com/products_nonsuch4.htm
The speaker in the link below is the only picture that I could find, but no other information wass available.
Full array with 16 drivers: http://www.audience-av.com/contact.htm
Any and all information will be appreciated.
Thanks
Norris Wilson
Previous Topic: Truncated horns
Next Topic: BR + TL + FH
Current Time: Thu Nov 26 09:23:42 CST 2026
