| Re: smoothing Zobel? tick but not if result is less than 91db/w! [message #21944] |
Sat, 15 March 2008 15:14 |
If you put any series capacitance in the circuit, i.e. high-pass, then you might want a Zobel. If you use inductance and capacitance, you'll almost definitely want a Zobel. But if you run the driver wide open with no crossover or just a bit of series inductance, you probably won't need a Zobel.
