Home » Audio » Speaker » Fostex surrounds?
Fostex surrounds? [message #21800] Fri, 13 April 2007 23:42
jm is currently offline  jm
Hello. Ihave heard some things about this drivers surrounds. First it's cloth surround leaks air thought it tiny little holes it has in the cloth surround. Second it adds peaks and bumps in the bandwith. Is this all true? I heard if fostex could do it diffrent it would be done. I also heard everything has to be as light as it can be so it can reach its 96db or it would be foam. Is there anything I can put on theses surrounds to keep the air from leaking out? The treatment has to be light and not harden the cloth or it will not work. Please help. jm
Previous Topic: Lycra Horns
Next Topic: ART Array Construction Begins
Current Time: Thu Oct 29 06:04:44 CDT 2026
