Home » Audio » Speaker » neat trick for corners in rear horns, xmission lines
neat trick for corners in rear horns, xmission lines [message #20863] Sat, 23 April 2005 14:58 Go to previous message
Russell Dawkins is currently offline  Russell Dawkins
Many years ago, when I was building a lot of transmission lines I came up with this trick for rounding the outside of the 180º bends in the line, in the interest of smooth airflow. It involves the use of self adhesive floor tiles (12" X 12") applied to the outside of the bend in the line / horn. Assuming an internal width or less than 12", get a few linoleum floor tiles with impact adhesive backing. Score them to internal width, minus maybe 1/16". Heat them in a very low oven (temp- about 150ºF is more than enough). Microwave might work. The point is to raise their temperatures to about 120º at which point they become very flexible. Bend them in to position (you might need two per curve, depending on the radius) and score and trim the excess length. You may need to re-heat them at this point. Peel off the wax paper backing and carefully put into position. Wiith a rubber mallet or hammer whack the edges against the inner cabinet surface. When it cools, it will be fairly hard and very strong, due to the curve and will be as close to a perfect curve as I can imagine. When I look at all these pictures of the internal construction of various rear horns / lines I know that one of the hardest things in the project must have been the cutting of those little corner fillers. It's just not necessary. The cavity could be filled, perhaps with sand, but that's often not necessary, either. Saves a lot of time and works way better than any alternatives I've seen. If I were building a rear horn I would definitely do it this way, it's probably more important than in a transmission line to have smooth, faired curves.
Russell
Previous Topic: Anyone tried these???
Next Topic: Checking with meter
Current Time: Thu Nov 05 23:28:41 CST 2026
