Home » Audio » Speaker » Effects of a low pass notch filter on BR versus TL: speculations
Effects of a low pass notch filter on BR versus TL: speculations [message #19880] Wed, 24 March 2004 11:21 Go to previous message
HI Everyone,
Since it is my lunch break, i got to thinking about the differential effects of a low pass notch filter on a bass reflex versus a TL box.
My initial thought was:
A bass reflex box emphasizes the midrange too, because of resonance. It emphasizes the midrange more so than a TL.
A low pass notch filter (one inductor and one resistor in parallel as a unit, and the unit in series with the driver) will allow for a HIGHER resistor value without losing clarity, since the midrange is getting emphasized in the BR box.
Of course, a higher resistor would lead to MORE bass.
So, for a given driver, the differential effect of a low pass notch filter will be greater for a well designed BR box, than for a well designed TL box.
I understand that the BR may not emphasize all frequencies equally, and a TL may be a bit less colored, but put that aside for a while.
What do you all think?
-akhilesh
Previous Topic: Xmax,Xbl2,Distortion
Next Topic: Can't reproduce a square wave
Current Time: Mon Nov 16 05:42:43 CST 2026
