Home » Audio » Speaker » Pro's and con's of mounting two woofers horizontaly?
Pro's and con's of mounting two woofers horizontaly? [message #19551] Thu, 17 July 2008 02:28 Go to previous message
I would like to acheive a high efficiency, but am not sure what is the best way to get there. I think the easiest way to achieve close to the desired 100db efficiency is to use multiple drivers.
I was wondering what the effects of mounting two midrange drivers horizontally above two horizontally mounted midbass drivers would be? In my situation, the drivers would be JBL 2118J 8" midrange from 300Hz to around 1.5khz, and JBL 2226J 15" midbass woofers from 40Hz to 300Hz.
Would the combing effects make it moot in an effort to obtain higher efficiency, creating to many negatives to make it worth the effort?
Any thoughts?
Norris
Previous Topic: Need help
Next Topic: Woofer directivity
Current Time: Mon Nov 02 08:46:19 CST 2026
