Home » Audio » Speaker » ?Horn Questions?
?Horn Questions? [message #19087] Thu, 08 February 2007 22:47 Go to previous message
Cuppa Joe is currently offline  Cuppa Joe
I've read that a horn's depth should be at least 1/4 wavelength of the desired cutoff frequency, while the mouth's circumference should equal the wavelength. The problem with a 90-degree (horizontal) conical horn is that the width increases 2" for every inch of depth added. If I wanted (for instance) a 160Hz cutoff, a depth of at least 21" would be required, which would make the interior width about 42" plus the width of the throat. That's a little too much like furniture or pet housing! Is there some way to obtain a lower cutoff (that is, below 200Hz) in a 90-degree conical horn without resorting to a mouth that wide?
I've seen some designs that look like they have 2 conical sections within the horn's horizontal expansion. Examples are the Peavey MB-2 and Rog Mogale's MT122. The first section, attached to the throat, appears to be about 1/2 the coverage angle of the second section terminating at the mouth. Is this still a conical horn, or is it a crude approximation of another horn type? When the wavelength becomes shorter than the first section's depth, does it beam at that coverage angle?
Previous Topic: Array Enclosure Plans ie Northcreek Designs
Next Topic: ?Horn Questions?
Current Time: Sat May 11 21:38:59 CDT 2024
