Home » Audio » Speaker » Mounting Woofer
Mounting Woofer [message #18254] Thu, 10 November 2005 16:20 Go to previous message
Well, I've decided to build something bigger than I started out wanting, a 3.5 ft box with a JBL 2226 and JBL horn. As I'm working on the cabinets I'm wondering if I should flush mount the woofers. I'm using 3/4" plywood, but could double up the front baffle if needed. Also, any thoughts on bracing?
Thanks!
Previous Topic: Acoustat 1+1 bias voltage idea
Next Topic: Folded horns with curves, about 60 – 500 Hz
Current Time: Sun Oct 18 17:07:38 CDT 2026
