Home » Audio » Speaker » Favorite flavors
Favorite flavors [message #17422] Fri, 21 January 2005 13:54 Go to previous message
I'm looking to get some opinions on favorites, specifically horn shapes and dispersion patterns. Or, for that matter, if your favorite configuration isn't a horn, I'd like to hear those opinions too. But more importantly, I'm looking for your reasons why you like that particular horn, shape or speaker configuration.
My favorites are horns with fairly wide dispersion. I don't particularly care for horn setups (or any kind of speaker, for that matter) that requires the listener to be in a very small "sweet spot." When I listen to a system, I rarely sit exactly on-axis, and sometimes the owner will instruct me to move into the preferred spot. But I am actually sitting there because I judge a system by off-axis performance as much as any other attribute.
To me, part of the goal is to make the system sound as good 10°, 20° and even 30° off-axis as it does on-axis. I am looking for a speaker that charges the reverberent field uniformly because it sounds far more natural than one that doesn't, in my opinion. If you have to sit in a half-meter wide sweet spot for the system to sound good, I'm not particularly impressed.
I know that some, if not most, audiophiles expect the listener to be seated in that one "perfect spot." Why would someone settle for only having good imaging and proper tonal balance in a "sweet spot" when they can have that same kind of performance over a wider range? I expect this kind of thing from planars and soft domes, but from horns? I see it as a throw back to technologies of 50 years ago. A good horn system has directionality that controls the pattern and fills the room without excessive wall and floor reflections. Horns offer a possibility of creating a good field of sound instead of a good line of sound.
So that's the flavor that gets my vote. I like horns, and I like them designed to cover the room. In addition to tonal balance and low distortion, a uniformly charged reverberent field is very important to me.
Previous Topic: correction filter for Fostex fe206e in a Jeriko
Next Topic: Thoughts on focused arrays and the phase problem
Current Time: Fri Nov 13 05:08:39 CST 2026
