Home » Audio » Speaker » E130-8 horn load or 2 on open baffle or K-Horn?
E130-8 horn load or 2 on open baffle or K-Horn? [message #17356] Fri, 14 January 2005 07:05 Go to previous message
adavis464 is currently offline  adavis464
If I take 1 and horn load it I get 105db to 106db.But if I take 2 on large open baffle I would get about the same spl.I also think a K-Horn is about the same.I've never heard a k-horn I have heard sealed and vented and bandpass.Or should I try all 3 and make my own mind up.K-horns sound intresting but no one sames to know how they work.Some I've seen like magnetars (rosie)But I think he just placed a exponetial curve cutout in front of a woofer box and they work as k-horns?I need a quality midbass solution.100hz 600hz or higher. thanks Tim
Previous Topic: Coral Beta 6 in Ebay
Next Topic: Power tapering Idea - Mass loading ?
Current Time: Sun Nov 22 22:05:59 CST 2026
