Home » Audio » Speaker » Short Coaxial Horns
Short Coaxial Horns [message #16766] Wed, 04 August 2004 11:27 Go to previous message
DR Carlson is currently offline  DR Carlson
Does any one have any info on using multiple drivers in a horn, which in turn shortens the length of the horn by a third or half or more? I came across the two sites listed below that mention it, but do not give any real specifics.
Steve Deckert at Decware:
http://www.decware.com/paper11.htm
“BUT MY FAVORITE is a ZEN DESIGNED series of cabinets I called the Wicked One. Pictured on the left, this formula for a binaural folded horn can be scaled also to work with a large family of drivers. It's neatest feature is the fact that I figured out you can share the last order of a horn flare between two horns if you couple them properly, thus reducing the size of your enclosure by half. A Wicked one is 12"H x 36"W x either 24" or 36"D depending on where you scale it. Not very big at all considering what it does. Trust me the name says it all"
And at the JBL site:
http://www.jblpro.com/pub/technote/PD%20HF%20TechNote.pdf
Tech note Volume 1, Number 29 pg.7
JBL Precision Directivity PD700 Series Co-Axial Mid/High Speaker System
It states that in using two drivers side by side, they are able to shorten the horn by 33%
if anyone has more info on this it would be very helpful thanks
Previous Topic: "Distributed Mode Radiation"
Next Topic: Looking to step in
Current Time: Mon Nov 16 05:42:44 CST 2026
