Home » Audio » Speaker » Eminence Beta 8CX
Eminence Beta 8CX [message #16419] Sun, 02 May 2004 03:24 Go to previous message
Has anyone used the Eminence Beta 8CX before with the reccomended APT-50 supertweeter? What's the quality like of both these components?
The Beta 8CX datasheet says its 89mm deep, but is it more deeper with the APT50 fitted or it is the same?
Does this driver 'sound' 'better' than a normal low eff commerical driver (for fullrange use)?
Might be cool to try a pair in a car.
Previous Topic: ALON I Crossover
Next Topic: To horn or not to horn?
Current Time: Thu Nov 05 00:13:22 CST 2026
