Home » Audio » Speaker » Subwoofer Horn
Subwoofer Horn [message #16267] Wed, 31 March 2004 17:04 Go to previous message
Been trying to get a 2.5 meter horn for 18" driver in a 100x90x48cm 'compact' size (for an 18).
Thats the horn dimensions... 100cm high, 90cm deep, and 48cm wide. Used a different folding pattern than what mike.e uses to get it more compact.... and can have big back chamber!
Assuming that you measure length like this:
Then length would be ~2.47m which is about 2.50m. Acoustic length line is the dotted line. I've heard you measure only on 'inside' dimension though? which is this?
Here is response:
Any comments/suggestions?!
Adrian
Previous Topic: Now _this_ is sculptural
Next Topic: My 30hz basshorn with 2226h
Current Time: Mon Nov 02 14:33:55 CST 2026
