Home » Sponsored » Pi Speakers » 3 Pi or similar for Small room - Near field listening?
3 Pi or similar for Small room - Near field listening? [message #96955] Fri, 01 September 2023 07:25 Go to previous message
rongon is currently offline  rongon
Hi, first post here...
I'm curious what the thinking is about speaker size as it relates to room size and volume levels. The background is:
1) I live in an apartment and I can't play music very loud (neighbors). I do love music, though. I was a working musician in my younger days, so I know what live acoustic music sounds like.
2) My living room (listening room) is about 12 feet wide by 24 feet long, with the usual nearly 8 foot ceiling. (Roughly 3.6 m W x 7.3 m L x 2.4 m H)
3) I value midrange clarity and treble 'sweetness' (lack of sibilance or harshness) above frequency extension. I can't hear above about 12kHz, and I don't need (or even want) very low bass response. It only upsets the neighbors. -3dB at 50Hz would work fine for me.
4) I sit only 4 feet from the speakers when listening. That's close to nearfield usage.
5) I would like to use low power vacuum tube amplifiers to drive the speakers. Maybe even single-ended. That means about 5W per channel of power (push-pull EL84-triode or 2A3, most likely).
I like the results I get with controlled directivity waveguide-equipped speakers. I bought a pair of JBL LSR305P speakers as an experiment and am very favorably impressed with the results, especially for the money. The waveguide/controlled-directivity concept works!
Previously, I was very happy with an old pair of Snell E-III 8" two-way floorstanders. The JBL 305Ps beat them for clarity, though.
I'd like to upgrade from the 305Ps -- significantly.
My questions:
1) Would the 3 Pi speaker be inappropriate for a 4 foot (1.2 meter) listening distance?
2) Does the 1 Pi speaker have a comparable off-axis dispersion characteristic to the 3 Pi's? Or is the dome tweeter much less controlled than the 3 Pi's horn in that parameter?
I don't have a firm bias for/against waveguides vs. dome tweeters, but now that I've experienced what uniform frequency dispersion does in my listening room, I want to preserve that and move up to a lower distortion speaker.
Opinions welcome and any advice would be much appreciated. Thanks in advance.
Previous Topic: Pi 4 plans
Next Topic: Which model?
Current Time: Tue Nov 17 12:43:33 CST 2026
