Home » Audio » Thermionic Emissions » New Production Tung Sol 6550, Penta KT88s (Concerning Audio Quality)
| Re: New Production Tung Sol 6550, Penta KT88s [message #97845 is a reply to message #97825] |
Sun, 07 July 2024 20:26   |
positron
Messages: 163 Registered: May 2020
Master |
gofar99 wrote on Wed, 03 July 2024 11:09Hi, I suspect that there are a number of other factors involved as well. Class of operation (A,AB,U/L etc) actual load impedance and any possible output load side anomalies, stability of the B+ from no load to full load. Regardless there is considerable room for all of us to find tubes that sound and perform well in our gear. Good discussion.
Yes, there are some other possibilities. However, my designs are superior
designs, and well within parameters. For instance, my line voltage only
varies 1 volt, 2 volts maximum during all conditions.
Concerning Class of operation, for newbies.
Class A has maximum plate dissipation at idle (some add a few ma. at Max signal output). How close to maximum plate dissipation will affect gas
release by the heated plate. As the output wattage increases (louder
volume), that output wattage goes to the speaker, not in the form of heat
on the plate. Thus the output power is subtracted from the maximum plate
dissipation.
UL operation is similar to triode, unless the screen dissipation is exceeded, then possible catastrophic consequences.
Class AB normally has higher peak cathode current vs idle current, thus higher peak plate dissipation vs idle dissipation. The average cathode current, and plate dissipation is a consideration.
I would think the main worries are space charge depletion at peak cathode current and a higher average cathode current, which shortens life in general. The peak, and thus average is often determined by the output transformer. A 2k ohm to secondary X output transformer will have a higher peak and average cathode current vs a 5k ohm to secondary X transformer.
A poorly designed amplifier design could have oscillation problems,
low frequency and/or high frequency. This can cause high peak and average cathode currents, which would shorten tube life vs lighter running of the tube(s).
An oscillation often causes a rectangular waveform, thus extended high
cathode currents. Of course rectangular waveforms have very high distortion characteristics. Guitar amps often use distortion in expression of their music. But it can occur in high fidelity amplifiers if a designer is not careful.
Stability of the high voltage usually results from two areas, line voltage
variations and inferior DC filter section designs.
Anyway, I shall see if I can determine, via experiments, what is the main
limitation of the JJ E88CC small signal tubes, and the new Tung Sol output
Tubes under excellent operating conditions.
One last consideration is the lack of plate dissipation. It takes a quite hot temperature for getters to work. I have noticed over the decades that the top getters are not as efficient as side getters, which are near the hotter plate structure. That tells me that tubes without side getters could easily have more internal gas than tubes with side getters, thus faster poisoning of the cathode oxides.
Cheers
pos
By: positron on Wed, 18 January 2023 23:01
By: positron on Sat, 21 January 2023 18:24
By: positron on Sat, 21 January 2023 21:33
By: positron on Sun, 22 January 2023 17:28
By: gofar99 on Mon, 23 January 2023 20:25
Re: Demagnetizing Tung Sol 6550, Penta KT88s
By: positron on Mon, 23 January 2023 22:12
By: positron on Tue, 21 February 2023 22:45
By: positron on Mon, 26 February 2024 21:44
By: gofar99 on Fri, 21 June 2024 20:50
By: gofar99 on Fri, 28 June 2024 20:46
By: positron on Thu, 16 March 2023 15:30
By: gofar99 on Thu, 16 March 2023 21:28
By: positron on Thu, 16 March 2023 22:17
By: gofar99 on Wed, 03 July 2024 11:09
By: positron on Wed, 28 August 2024 23:11
By: positron on Sun, 06 October 2024 22:36
By: positron on Mon, 04 August 2025 12:43
By: positron on Thu, 28 August 2025 06:31
By: positron on Sat, 30 August 2025 20:50
Current Time: Sat Jul 11 18:24:40 CDT 2026
